Latest PWP version (although issue occurred in last version as well).
Either this doesn't work or I'm doing something wrong somewhere, or I don't understand what it is supposed to do.
Two thumbnails open (and one image in workspace, of course), one the original (image 1), second (image 2) a result of a Composite action on image 1.
Shift+click both images and press Browser button "Copy selected images" to get Confirm "Copy to new branch?".
OK > Browser window shows two new thumbnails (3 and 4) which are black and half size of other two thumbnails. Also opens image folder with "File name: *.*" and only options Open and Cancel.
Press Cancel > "Alert. No files selected. Try again?". Pressing Yes opens same folder and options.
Press No > "Alert. Abort and clear workspace?"
Yes > workspace clears all files. No > the two new thumbnails turn red in color.
Is this the way it is supposed to happen?
Re: Copy selected images
I assume you mean Ctrl-click. In any case when one of the selected images is a top-level image (such as a File Open), you need to open a different image to serve as the copied top-level image. This is similar to cloning an entire branch in previous PWP versions which is why it is asking for the name of a different file to open.
When you Cancel, you are failing to provide a new file to open.
If you want two composites based on the same image, insert a side branch after image 1 and then copy image 2 to the new branch.
If you copy both image1 and image2, you need to select a different file for image1-copy and then image2 will be the same composite transformation applied to image1-copy.
If you have a series of transformations starting with a File Open and want to replicate them, but applied to a different file, then select the entire branch and copy it. This asks for a new filename and then copies all the transformations after the new File Open.
I will check out the situation you described and see if I can make it work better.
I think I see where my confusion lies.
I presumed that, because the title of the button is "Copy selected images" , that if a chain of images was selected (by shift + click) all images were copied into a separate branch, not just the Transformations related to the images.
Perhaps a minor change to the title of the button to "Copy selected transformations" or similar?
Yes, I tend to use image and transformation interchangeably and others have pointed out that this is confusing.
