latest version 8.0.53
Clicking OK of Clone Tool Transformation does not start downstream recalculation. For example: Crop, Level and Brightness Curve.
You need to re-edit the first image below Clone to start it.
However once recalculated, if you go back to Clone, Undo last operation and Click OK, recalculation is triggered.
Clone OK does not trigger recalc
Re: Clone OK does not trigger recalc
I just tested the Clone Tool, followed by the Levels and Color - clicking OK in clone seems to recalculate Levels and Color downstream as well.
However, if e.g. Crop is added after the Clone, it doesn't.
It seems even more tricky. After some more cloning it looks as if that sometimes it does recalculate but mostly not. At first I thought that it worked only after the first forced recalculation, but it did not prove to be true.
Fixed for next release -- it only happens when you are editing an existing clone, paint or smudge transformation and then apply new strokes.
