Update Available - Version 8.0.52
An update is available to Version 8.0.52 (23-Feb-2020)
Added optimizations to all transformations to prevent most unnecessary recalculations of images that depend on the transformation. For example, an Apply followed by an OK no longer triggers a recalc.
Fixed problem in Drop Shadow transformation.
Fixed Exiftool not installed error.
Removed inactive Clone Side Branch command.
Removed fix from 20-Feb regarding clicking on thumbnails not zooming to fit.
Renamed the Edit/Add Branch command to Edit/Add Branch to Splitter. This command now works if the current image is either a splitter or a side-branch. If it is a side branch, it adds and new side branch to the splitter immediately above the side branch.
Fixed problem with closing transformation dialog boxes with active masks not resetting the display from split screen.
