Update Available - Version 8.0.50
An update is available to Version 8.0.50 (20-Feb-2020)
Fixed problems with clicking on a thumbnail to select a new image not always zooming it to fit.
Fixed problem with File Close from main menu not working.
File Open: fixed problem with crashing after opening multiple files, making one of the last ones current, and then opening a new, smaller set of files.
Recover Workspace Script command now remembers which workspace you chose the last time.
High Contrast: fixed problem that could cause very small variations in output image when reprocessing the same image with the same settings.
File/Preferences: added an option to change the dependency coloring scheme in the image browser from red/green to blue/orange to accommodate certain types of color blindness. If you select this feature you will need a couple of new bitmaps and a full install.
Fixed problem with crashing when closing an image that was an auxiliary input to a transformation that also had an associated mask. This situation could arise with Composite, Layout, Repeat, Stack Images, Watermark and Wave.
Fixed some problems with file extension handling when saving settings files.
Re: Update Available - Version 8.0.50
After settung the Dependency Colors to "Blue/Orange" I receive at the nest start the following message:
Error message
Error message
Select Downstream1.jpg (21.32 KiB) Viewed 2111 times
It looks like I forgot to add the new bitmaps to the installer -- will fix for next release.
