Compare
Compare
Is there a reason why image B in Compare cannot be an image further down the same branch?
Re: Compare
Compare does have an output image, depending on the type of compare you are doing. Comparing with an image further down on the same branch would create a circular reference.
You can still do this, but you need to add a splitter and put the compare on the side branch.
