Update Available - Version 8.0.41
An update is available to Version 8.0.41 (22-Jan-2020)
Closing a window that takes control of the image area (e.g. a color picker, mask dialog box, readout tool) now restores control to the current transformation dialog box, if any.
Updated the web site to use an SSL certificate. This means that browser access will be secure as long as you link to it using https://... Instead of http://... . Please update any bookmarks or saved links accordingly, although insecure access will continue to work if you don’t. Otherwise you should not see any difference.
