Reading individual image scripts in batch
If images are processed and saved along with their script sidecar files, when I load those output files again and run them in batch again, would each of the images read its corresponding script file and adjust the transformation settings accordingly?
Re: Reading individual image scripts in batch
If you load the script file you rebuild the image from its history. If you load the image file you just get the image.
