Brightness Curve
Posted: December 28th, 2019, 2:29 pm
Couple questions:
1. If I click in the histogram to set a point, and I don't have the cursor exactly placed on the line, a point will be placed but the line will jump slightly. Without shift-clicking in the image, is there a way to place a point on the line with no line movement. I know the movement I reference is minimal, but the OCD in me screams every time I do this (should be a laughing face emoji here for this last sentence).
2. I am trying to better understand the Advanced Mode - What do the default settings represent? Are these just arbitrary settings that are recommended for most images? I ask this, because in the example given, the settings are markedly different from the defaults, especially in the Detail slider.
3. As changing the settings in Advanced Mode can cause quite subtle changes, is there a method, without completing the full operation, to visually observe the changes each setting will have. For some changes, to better see where those changes occur, I find I have to Composite the before/after with an Absolute Difference, then even use Levels and Colour to get maximum dynamic range, which seems a bit long-winded.
4. And last, is there a way to reset only the Advanced Mode settings, without resetting the curve itself?
