Update Available - Version 8.0.20
An update is available to Version 8.0.20 (19-Dec-2019)
Zoom Blur: now lets you drag the center of the zoom to any desired location in the input image.
Added a few new picture frame images for the Frame transformation.
Fixed problems with clicking probes outside the input image.
Levels and Color, Levels and Color Tool, Autorange, Color Negative: reworked dynamic range sliders to use one consistent code base. Shift-clicking on the dynamic range slider sets it to full range; Ctrl-clicking resets the sliders to the tic marks (if any).
When saving script files as a side effect of saving image files, the script file name is now added to the recently used file list at the bottom of the File menu.
Fixed numerous problems with saving files whose filename includes period, such as “a.b.c”. Also added a check for correct extension when saving settings files.
Edited the warning message you get when replacing an image which has size-dependent downstream images.
