Update Available - Version 8.0.15
An update is available to Version 8.0.15 (27-Nov-2019)
Warp: holding down the shift key while dragging one of the vertices of the overlay grid constrains it to move only horizontally or vertically.
Fixed problem with loading default file save script preferences from previous versions incorrectly. If you have used 8.0.12 – 8.0.14, check your File/Preferences/Set Default File Save Options to make sure your default include script settings are correct. If not, you should be OK using this latest release.
Fixed problems with image area scroll bars disappearing in some cases.
In Scroll Mode, when using the mouse wheel to zoom in, the part of the image at the cursor location is centered, to the extent possible. This facilitates zooming in on a specific part of the image.
