Feature suggestion
Posted: November 26th, 2019, 12:07 pm
1. Zoom. Seems the only option is to zoom an image from center. It would be nice to be able to move that point to other locations in the image (perhaps start with a cross-hair dead center, then move it at will) so as an example, if an object (flower etc) was off center, the zoom could emanate from the center of that object.
2. Warp. I often use the warp tool to only correct keystoning by leaving the two bottom control points as is and moving the two upper points towards the center until they line up with a tree/building side etc.
However, it is difficult, unless zoomed in considerably (which then requires scrolling the image back and forth along the top), to ensure the two top points are at the images edge, so the result is not cutting/adding a couple pixels. Adding requires a second step of cropping which results in the image being a different size than the original.
It would be nice to have an option to constrain the points to stay at the edge as moved. So as an example, if doing as described above, one could click on the top right point and move it left along the top edge. Maybe even make it applicable to all points for each edge, so the top right point could be moved along the top edge or down the right edge etc.
Not sure if any of this is possible or even desirable.
