An update is available to Version 8.0.13 (25-Nov-2019)
Fixed bug that could cause Picture Window to go into an infinite loop when canceling a transformation after just starting it. This bug was accidentally introduced in 8.0.11 when adding code to automatically close open transformation dialog boxes.
Watermark transformation: eliminated the Transparency slider and changed the Watermark Mask to and amount control. This lets you set the transparency by adjusting the amount slider or create a mask for the watermark image.
Update Available - Version 8.0.13
