Spectial Effects/Conformal Mapping
MikeG
Post by MikeG »
1. On my system the dialog box for Conformal Mapping is a tiny bit too small in the vertical dimension. Such that I cannot operate the reduce button on the anti-aliasing function. Does anyone else have this?
2. Fun to play with, that's for sure, but has anyone found a use for this transform? Following are a couple of examples that I might use now and again.
The first attachment is of a layout in portrait mode and the second attachment the output of Conformal Mapping using Type asin(z), Tile On, pre & post magnification 0.8168, 3.0232
Unfortunately only 3 attachments are allowed so I've omitted the second input photo which was a sinlge landscape portrait photo. The third attachment is the output of Conformal Mapping using Type ln(z), Tile On, pre & post magnification 0.8168, 3.8026
I'd be very interested to see other examples of this transform in action.
Mike.
Layout 4 on white_resized.JPG (44.89 KiB) Viewed 8021 times
Layout 4 on white-cfm asin_z 0_8168 3_0232_resized.JPG (45.62 KiB) Viewed 8020 times
P1100787-cfm ln_z 0_8168 3_8026_resized.JPG (46.14 KiB) Viewed 8019 times
Re: Spectial Effects/Conformal Mapping
Thanks for posting the examples.
The dialog size problem is a Windows 7 problem and will be fixed in the next update.
I've just noticed that the Conformal Mapping window shows a double arrow for resizing when moving the mouse to its borders (hight, width and diagonal)
but only allows resizing in width. OS is Win XP.
It's been awhile since I played with the conformal mapping transformation, but it appears that the control window size/border issue in Windows 7 is still here. I thought I remembered this earlier conversation about a fix, so I'm just checking in. (Picture Window Pro 32 v6.0.10)
I don't see the problem here - can you post a screen shot of the dialog box?
Thanks Jonathan. Here is what the transformation window looks like on my system: Win 7 Home Premium SP1; PWP 32 v6.0.10
Sorry - the problem does exist in the currently available version but I can confirm it has been fixed since then.
Okay, great, I'll look forward to the update. Thanks.
