All for transforms to be added to the Title/Ribbon bar
Allowing transforms as quick buttons in the menu/ribbon bar... Not sure if it is hard or easy to do but there is a lot of space to the right of the standard buttons....would be a nice addition to be able to check a box perhaps in the transform and have it added to that space...great for 6 or 7 common tools to be even more handy....just a thought...
Re: All for transforms to be added to the Title/Ribbon bar
The biggest obstacle at this point is creating roughly 120 different icons - one for each transformation. However, there is an enhancement coming in the next release to Quick Pick which will place the most commonly used transformations (based on accumulated usage statistics) at the head of the list and let you select up to 9 of them using the number keys.
Thanks for the reply Jonathan. Any and all shortcuts are welcome...Any thoughts about customizable workspaces...so basically allowing the user to checkoff menu items they want and those they don't use can be dropped to stream line things....then you could load trimmed down task specific workspaces and if need be on occasion still get at a module not there via the quick picker or your could reload the default one......some version of that in any case...again I have not idea how hard or easy that would be to implement...
