Compare Dialogue Display
Posted: August 12th, 2019, 2:16 pm
Ref: PWP8 Beta 12-Aug-2019; Win10 Home
If the Compare dialogue has a vertical frame scroll, Image A will appear to flicker due to a height difference with Image B as the slider is moved...
- Compare.jpg (40.7 KiB) Viewed 5387 times
Re: Compare Dialogue Display
Posted: August 12th, 2019, 2:25 pm
If the two images you are comparing have the same dimensions, I don't think this happens. Compare lets you compare images of different sizes but pads out the smaller one with the background color.
Posted: August 12th, 2019, 2:45 pm
Both A and B are: 3024x4032 pixels @ 72 dpi
B is a v1 of A
Images are Zoomed-in [+] rather than "Zoom to Fit" but I don't recall the ratio.
Posted: August 12th, 2019, 2:48 pm
OK, I see what you mean -- this is apparently being caused by the A | B label being redrawn over the top of the images. Should be fixable.
