Bug fix release 13-May-2019
Posted: May 13th, 2019, 10:07 am
I have posted a new release (13-May-2019).
Fixed memory allocation problems in Clone, Paint and Smudge when being replayed from a script. Also fixed memory leak associated with undo followed by using the tool again.
Fixed memory leaks when executing Layout, Texture or Line and Arrow tool from a script.
Fixed memory leak when closing all images in some cases.
Fixed some issues with loading/saving workspace scripts recording the name of the last workspace used, incorrectly in some cases.
Fixed problem in transformations that do not preserve image size (e.g. Add Border, Crop, Warp, etc.) with zoom to fit after changing the display tool bar in some cases.
Dropping a script file or workspace script file on the main image area now opens it (but only if it is the only file being dropped).
When deleting a branch from a splitter, the remaining branches, if any, are now renumbered unless they have been assigned a name. Branches are also renumbered after reading a script or workspace script file.
