"Save without image Names" scripts do not open images
Ref: PWP8 Beta 02-May-2019
Previously "Save without image Names" setting scripts will not open images, even if the image is the original starting image from which the script is derived, however if the script is an image script, the image will open and script processes with the ability to change/add images for batch processing.
190502 Beta.jpg (74.82 KiB) Viewed 2066 times
Script text:
script 1.0
PWP_Version ″Picture Window Pro 8.0 Beta 2-May-2019″
color_management enabled 1 on_mismatch 0 on_batch_mismatch 1 acs_profile ″sRGB Color Space Profile.icm″ gray_acs_profile ″Gamma 2.2.icm″ wcs_profile ″sRGB Color Space Profile.icm″ gray_wcs_profile ″Gamma 2.2.icm″ monitor_curves_file ″″ monitor_curves_enabled 0
image index 1 caption ″DSCF2274.JPG″ saved_as ″″ saved_on ″″ parent -1 bypass -1 same_size 0 size_specific 0 breakpoint 0 n_inputs 0 n_masks 0 command ‴file_open 0 n_files 1 current 0 show_progress 1 from_default 0 file1 ″″ time1 ″″‴
end_image
image index 2 caption ″Multi Color Balance″ saved_as ″″ saved_on ″″ parent 1 bypass 0 same_size 1 size_specific 0 breakpoint 0 n_inputs 0 n_masks 1 command ‴multi_color_balance 0 npts 2 white 2 black 2 probesize 1 curpt 1 amount 1 -1 0 0 ″Amount: ″ ″Mask″ display 2 sync_scroll 1 auto_preview 1 enable1 1 inconsistent1 0 src1 10407 dst1 0 enable2 1 inconsistent2 0 src2 fefcfe dst2 ffffff‴
end_image
image index 3 caption ″Color Curves″ saved_as ″″ saved_on ″″ parent 2 bypass 0 same_size 1 size_specific 0 breakpoint 0 n_inputs 0 n_masks 1 command ‴color_curves 0 curve1 2 2 0 128 255 128 curve2 5 2 0 0 18 26 89 166 204 222 255 255 curve3 2 2 0 0 255 255 colorspace 0 component 1 mask_histogram 0 amount 0.19974 0.66697 0 0 ″Amount: ″ ″Mask″ display 2 sync_scroll 1 auto_preview 1‴
mask base_image 3 mask_number 0 base_input_index -1 initial_image -1 initial_mask_index 0 initial_level 0 caption ″Mask″ command ‴mask 0 nx 1000 ny 563 mask_color 0 mask_transparency 2 initial_level 0 n_op 1 command1 operation 7 mask_mode 0 mask_operation 7 colorspace 0 sample ff minb1 113 maxb1 993 minb2 26 maxb2 922 minb3 0 maxb3 1024 minw1 143 maxw1 963 minw2 102 maxw2 845 minw3 0 maxw3 1024 ‴
end_image
end
Re: "Save without image Names" scripts do not open images
I am aware of this issue and it has been fixed for the next release which I hope to get out soon.
