A printing hitch?
A printing hitch?
I opened the print dialog and set it to print an image. Then I changed my mind, opened a layout thumbail with a small crop and printed it first. Then I wanted to print the previous image and noticed that there is still the print thumbnail with the previous image settings. When I click OK to print it, is said that the margins are to wide, even though the image was small enough to fit into the printing area.
Only after I closed the thumbnail, reopend the print dialog, used the same settings I was able to print it.
I have not tested it more as I had no more images to print, so cannot confirm it as a repeated problem.
