A question about the bypass feature
Posted: April 2nd, 2019, 7:47 am
If you bypass a transformation, everything downstream is recalculated. If you then decide to remove the bypassed step for good, everything downstream is recalculated again. Is it necessary?
Sometimes bypassing and removing transformations might be a frequent step while the workflow is being tuned.
