Bug fix release 7-Oct-20184
I have posted a new release (7-Oct-2018) in full installer and executable-only versions. Minor changes to help file.
You will need to do a full install the get a new required DLL.
When activating the Mask dialog: If the display is split screen or the input image is being displayed, the display is not zoomed to fit or switched to split screen. If only the output image is being displayed, the display is reset to split screen and zoomed to fit.
Modified program to begin working with CUDA (using graphics card to accelerate the program). Under Help/About Picture Window Pro, there is now a line at the bottom of the About box that tells you if CUDA is available on your computer or not.
Speeded up Texture transformation using CUDA to compute the inverse FFT and performing some other operations in parallel.
