Bug fix release 21-Aug-2018
Posted: August 21st, 2018, 7:54 am
I have posted a new release (21-Aug-2018) in full installer and executable-only versions. Minor changes to help file.
Color Balance: Fixed problems with Custom white balance not being set when it should be.
Fixed problem of Cancel button not propagating changes if an Apply has been previously performed.
Added two new Edit commands that operate only on top-level images: Clone Top Level Image and Clone Top Level Branch. Clone Top Level Image creates a new top-level image with the same transformation and settings as the current image. Clone Top Level Branch creates a new top-level branch that is a copy of the current one. These commands can be accessed either through the main menu or the right-click on a thumbnail popup menu in the image browser.
Re: Bug fix release 21-Aug-2018
Posted: August 21st, 2018, 9:16 am
by davidh
Added two new Edit commands that operate only on top-level images: Clone Top Level Image and Clone Top Level Branch. ...
Thanks a lot. This will save time for more experimenting.
