Posterize Reset and Refine Palette
Posted: August 17th, 2018, 2:44 pm
Reset does not close all open Color pickers. If you leave them open, re-add the color patches and run Auto Palette some of the patches are black.
Refine palette now works differently. Sometimes it seems not to work at all, or any adjustments are practically invisible. Previously the changes made mostlu clearly visible.
1. Add a few color patches and run Auto Palette. Then run Refine Palette and the colors are just reordered. Sometimes there does seem to be a very sligt adjustment to one of the colors.
2. Run Refine Palette repeatedly and the output looks the same.
3. Change the colors patches by probing the input image and run Refine Palette. There might be some visible adjustment, sometimes a color is not adjusted but completely changed or replaced by anothe color.
4. Again run Refine Palette repeatedly and there do not seem to be any visible adjustments
5. Change the colors patches by clicking respective Color Pickers picking colors not existing in the input image. When you run Refine Palette, you might get almost completly different colors, not just adjusted.
The Helps says "...PWP makes an incremental adjustment to the existing palette colors...".
Does the "existing palette colors" mean the colors existing in the input image or in the color patches?
It is difficult to say which or whether a color was adjusted or replaced because as I noted in 1. Refine Palette seems to reorder the color patches as well.
