Picture Window Pro Update Posted
Posted: October 26th, 2009, 9:13 pm
				Picture Window Pro 5.0.1.6 is now available for download.
PWP 5.0.1.6 updates the raw converter to support recently introduced cameras. It also contains two enhancements and fixes reported problems. A few of the highlights are:
As per a number of user requests, workflow now has a manual sort function. To use it, select Manual Sort from the workflow thumbnails Options menu. This brings up a dialog in which you can rearrange images by dragging them to their desired locations. After you click OK, the images stay in the order you specified until they are resorted. Any workflows you run will use the images in the specified order.
An appointment style calendar have been added to the Calendar transformation. You can also display days of the week in abbreviated and fully spelled-out formats. Finally, a new 'increment date' feature in the Calendar widget lets you use workflows tocreate multi-page calendars.
Additional details of changes are listed here: http://www.dl-c.com/update50.html
You can download the new version from http://dl-c.com/content/view/23/54/
