Adjust two more observations
Posted: July 27th, 2018, 3:10 pm
1. Dragging the Adjust dialog triggers Curve reprocessing.
2. Color spaces, Channels and curves with histogram are not always synchronized.
for example, if you change the HSL/L to HSV you might get HSV/H, (the first item in the list ?) with the right curve and histogram
or, if you change HSV/V to HSV/H and then HSV to HSL - you might get HSL/L with H-curve and histogram
The main Reset does not always correct it.
There does not seem to be any visible regular pattern at it varies depending on what you change, but it seems that the channel and curve with histogram somehow lag behind.
