Posterize Auto Palete just resets remapped colors
Posted: July 14th, 2018, 6:06 am
If there is a user Default Setting, Auto Palete does not remap the colors, but does the same as Reset Remapped Colors - it just resets the remapped colors.
One more observation:
There is no longer the command Reset all. It has been replaced by simple Reset which resets setting to the saved defaults if there are any, or to system B and W.
If you want to reset all colors to black and white, you have first to clear your saved default settings and then use Reset or click the counter until you get to number two.
I think that the Reset all comand was useful especialy when there were many colors and you wanted to start afresh but preserve your default settings.
Still the current Reset is also useful, it could be renamed to Reset to Defaults.
