Bug fix release 29.5-Apr-2018
I have posted a new release (29.5-Apr-2018) in full installer and executable-only. Minor edits to help file.
Removed unnecessary image recalculation when clicking OK for all transformations except those that have separate previews (e.g unsharp mask, advanced sharpen, frame, layout, etc.).
Fixed problems with several transformations ignoring Apply button.
Image menus for auxiliary inputs now correctly exclude all downstream images.
Crop transformation, if default settings have proportions other than arbitrary, reset the cropping rectangle as large as possible with the specified proportions. If the proportions are arbitrary, the cropping rectangle is set as a proportion of the image width and height. Thus, if the original image was cropped to include just the right half and those settings were saved as the defaults, applying those settings to other images would also crop just the right half, regardless of the size and shape of the image.
Fixed bug in Lens Distortion causing changes to Scale to affect the distortion correction.
Fixed bugs in code that converts multiple images with different profiles to the same color space.
Fixed problem causing Add Side Branch command to be grayed out for splitters.
