Edit Transformation command brings PWP down
Posted: April 15th, 2018, 9:05 am
1. open an image
2. add Side Branch
3. use the mouse right button and click on the Splitter box or a Branch box and select the Edit Transformation command from the local menu -> it brings PWP down
This does not happen with Clone branch on the top image because the command is grayed out. But it does beginnig the first output image.
A cosmetic one:
Edit transformations of local menu used on the input image opens Replace Existing File box. There are no transformations yet. A possible candidate to be grayed out too?
2. add Side Branch
A cosmetic one:
