Bug fix release 6-Apr-2018
Posted: April 6th, 2018, 10:22 am
I have posted a new release (6-Apr-2018) in both full version and executable-only. The only reason to download the full version is to get the latest version of the help file which mostly has some cosmetic edits.
Readout tool settings: added Display 0..255 option.
Readout tool now works on both halves of split screen. Other probes now work on the left, right or both sides of a split screen, depending on what is appropriate for the currently active tool, control or transformation.
Fixed problem with various probes operating outside the main image area.
Fixed problems with tool probes not being activated by clicking in the title bar of the Readout, Magnifier and Histogram tools.
Fixed problems with scroll tool and Alt-drag not working with split screen. Now, if synchronized scrolling is in effect, scrolling one image scrolls the other at the same time. If synchronized scrolling is turned off, scrolling is limited to the image being dragged.
Halftone Transformation: fixed bug causing crash after double click of existing image.
Equalize Transformation: fixed bug from aborting histogram match.
Frame: cropping rectangle is now always maximized when changing Base Size On selection.
