Using the Key + with a profile-converted image
Posted: March 26th, 2018, 5:39 pm
Color management = off
A. On Profile Mismatch = Ask on Mismatch
1. Open an image and confirm the Profile Conversion
2. Press the key +
3. The "Confirm Profile Conversion" box is redisplayed
4. Click the Cancel button
5. The original image disappears and a new red thumbnail with Error" msg is added to the branch.
6. Dblclick on the red thumbnail opens the "Replace Existing File" box
7. Click on the Cancel button restores both the image and the new thumbnail
Additional findings:
Closing a thumbnail and then its branch label reopens the "Confirm Profile Conversion" box and you are back at the step 3
If you click OK instead of Cancel at the step 4, the original image just disappears with no error thumbnail.
If the loaded image does not need a profile conversion, the image just disappears after the Key + is pressed and a new thumbnail is added to the branch.
B. On Profile Mismatch = Convert or Don't Convert
The original image just disappears after the Key + is pressed and a new thumbnail is added to the branch.
No problem with closing of the thumbnails
Conclusion:
The problem seems to be connected to the cancelled profile conversion with Ask on Mismatch set up.
I wonder why the original image always disappears or is hidden after Key + is pressed. To display the new copy of an image it needs to click at its newly added thumbnail.
2. Press the key +
Conclusion:
