PWP 8 Early Alpha Release Available for Download
Posted: March 25th, 2018, 9:08 pm
It's been a long road -- I hope it was worth it.
The download page is:
http://www.dl-c.com/PWP_Download.html
Please read the release notes first.
While much of this early release is working, parts may be buggy, so please don’t use this version for serious work. Although I will try to maintain compatibility, it is not guaranteed at this point that scripts you create will work with newer versions, so it is probably best to use this feature sparingly for now.
Currently there is only a 64-bit Windows version – if there is enough demand for a 32-bit version I will consider trying to put one together later.
Reporting Bugs and Feature Requests
The more specific you can be regarding bugs, the easier they will be to fix. If possible, please include the exact sequence of operations that fails. I will be fixing bugs and releasing updates every few days, so check the downloads page frequently. Please report bugs or feature requests in the PWP 8 Beta section of the message board or directly to me at jsachs@dl-c.com.
Documentation
For now, the only documentation is the help file which should describe everything. The Getting Started topic in the help file is a good place to start, and it points to other general topics you may want to browse before jumping in with both feet. I hope to create some video tutorials when the program is a little more stable.
Documentation
