Paint Tool - Softness
What does the 0-100 slider for Softness represent? I see Spacing and Fadeout show a % figure, but Softness (and Transparency) does not have the % attached, so I assume the numbers are not a strict percentage of the radius of the tool which gradates outwards to the radius of the tool (in other words at 50, the inner solid area is 50% of the radius, then it gradually goes light to the full radius size).
Re: Paint Tool - Softness
As you guessed, softness determines how far out the brush is solid. Then the falloff from there to the radius follows a cosine function. The omission of the % sign was an oversight and has no special significance.
