Sharpen Main Toolbar button causing PWP to "stopped working"
Posted: April 21st, 2016, 12:17 pm
I am consistly getting a "Picture Window Pro/32 7.0.18 has stopped working" dialog with Vista Home Premium and latest Patch Tuesday's updates when:
1) open a large [4896x3264} 24-bit color JPG image file...
2) perform Color Balance with default settings using the Color Balance Main Toolbar button...
3) attempt to perform Sharpen using its Main Toolbar button on the resulting 2) image...
A "stopped working" dialog does not happen if Sharpen is selected from the Transform drop-down menu or if another transform is performed using Toolbar buttons and/or Transform menu in step 2)...
The system problem is described as: "BEX" with Exception "c0000409" and OS version: 6.0.6002.2.2.0.768.3... ...resetting/clearing Sharpen's saved Default settings has no effect.
P.S. I did have difficulties on this "old" computer with Windows Update lastest "Patch Tuesday"'s [Apr 12, 2016] updates that necessitated utilizing " MicrosoftFixit.wu.Run.exe" which re-initializes UpdateHistory to "None" causing more than the usual number of updates to be downloaded and installed. Before running the "Fixit", I restored the system to Apr 9, 2016 when Windows Update was working properly. I do not recall if the Sharpen Main Toolbar button access to Sharpen after a Color Balance was shutting down PWP prior Apr 9, 2016...
