Juxtapose -- PWP 32 v7.0.18
1) Open 3 images to be Juxtapose...
2) Open Juxapose; select an Input and a Second images; and Apply with defaults
3) Set Input equal to the resulting 2) image and Second to the 3rd image of 1); and OK with defaults
The resulting 2) image remains in History??? with the Error note: "Window in use by Juxtapose - Cannot close -- OK" and will not close even if the resulting 3) image is saved/closed...
Also, the PWP session cannot be ended unless the Task Manager - End Task is used.
Vista 32 Home Premium
Re: Juxtapose -- PWP 32 v7.0.18
Same here on Windows 10 64 bit.
It works fine when using OK in den's step 2, but with Apply the image can't be closed anymore.
Thanks - fixed this for the next maintenance release.
