Grid in Workflow Preview
I'm running a workflow in which the images are rotated slightly with Level and I can't figure out how to turn on a Grid in preview, which would help to check how straight they are overall. Is there a way?
Re: Grid in Workflow Preview
To use the grid:
Select the Window to be gridded. It can be a preview or image window.
Slect Window/Grid from the main menu.
Set the number of grid divisions and click OK. (The default is 1, which shows no grid lines.)
Kiril,
Grid is greyed out in Workflow (at least i did not find a Widget where it is active).
I think it would be a useful addition to be able to use grid in workflows, too
Sorry -- I didn't notice that the question was related to workflow. You are correct. For technical reasons, grid is currently not supported in the workflow image and preview windows.
