Brightness curve - detail control bug???
johnp
Post by johnp »
I opened a jpeg color image and played around with the Brightness Curve : Detail Control
feature. I basically turned it on & off looking at how the image changed with
various settings.
I then converted it to monochrome using a green filter.
I then tried the Brightness Curve : Detail Control feature and I could toggle it once, then
it stuck and I was not able to change it again without closing the tool and re-starting it.
It seemed to work fine with a color image.
I'm running Window 7.
John P
Re: Brightness curve - detail control bug???
John,
As a workaround, you can convert the black and white image ( 8 bit) to a 24 bit color image with the Convert Transformation.
Thanks for the report. I ran into this problem myself a week or so ago and have already fixed this for the next release.
