Hi Kiril
I would be grateful please for help on this.
When I use Ctrl - Left Mouse Click to select individual photos to drag to the Workflow dialog box, I am finding that after selecting about 6-8 individual photos, the screen blinks, and the selection is lost, before I can drag to the Workflow dialog box.
(No trouble using the PWP icon to select all photos and drag across.)
This makes it difficult to manually drag only those photos in a folder for treatment that need it, to one open workflow.
(I am using Windows 8.1, PW Pro 64 v 7.0.16.
i5 CPU with 12 GB ram.)
Thanks, Mark.
Problem selecting individual files for workflow
Re: Problem selecting individual files for workflow
Mark,
I suppose you try to select the pictures in PWPs Browser ?
The problem you describe occurs when you move the mouse while clicking, and if it is just a tiny little bit.
It tries to copy the images, which does obvisly not work on themself, and deletes the selection.
Concentrating not to move the mouse I was able to select 20 or more images and drag them to the Workflow window.
If something can be done to reduce that sensitivity on movements ? Probably Jonathan or Kiril will jump in.
