Rotating images and methods
Posted: April 4th, 2015, 12:53 am
There are at least 4 transformations that could rotate an image by an acute angle:
- Level
- Warp
- Crop add border
- Composite
If only rotation is performed by any of the above, do they use similar resampling algorithms? Which one would be the best (the least blurry, or with the least amount of artifacts, for example)?
Cheers!
Re: Rotating images and methods
Posted: April 4th, 2015, 3:12 pm
They all use the same resampling code.
Posted: December 6th, 2015, 11:51 am
It looks like rotating in Crop/Add Border uses some sharpening routine at the end. Do they all do?
Posted: December 6th, 2015, 12:41 pm
Also, Level seems to execute the rotation part much faster than Crop/Add Border. I'm not sure how different the results are - I can't detect much difference.
Posted: December 6th, 2015, 6:40 pm
Level is faster because Crop rotates the entire image at full resolution to speed up subsequent operations at the same rotation angle -- not be cause of any difference in resampling.
Posted: December 6th, 2015, 10:36 pm
And the sharpening part of Crop rotate - is that common to all, just happening silently?
Posted: December 7th, 2015, 5:14 am
Am currently on vacation without access to the code.
Posted: December 8th, 2015, 10:04 pm
Only Crop automatically sharpens after rotating. It does the equivalent of the basic Sharpen function (with method = Sharpen) which does light sharpening to offset the slight blurring from the bilinear interpolation used to rotate the image. You can get the same effect in Level, Warp or Composite by sharpening the output images. Otherwise the effects should be more or less identical.
Posted: December 10th, 2015, 11:13 am
Cheers!
