Command Line for Workflows
Thank you for implemening this feature request:
http://www.dl-c.com/board/viewtopic.php?f=4&t=773
It works fine with IMatch 5.
I created a *.cmd file, created a link on the desktop for this *.cmd file and added it to IMatch 5 as an application.
--- *.cmd file -------
"C:\Program Files\Digital Light & Color\Picture Window Pro 7.0\Pw70.exe" "C:\Users\Winfried\AppData\Roaming\Digital Light and Color\Picture Window\Workflows\MoveToDateFolder.wfl" %*
migrated to Windows 10 in Nov. 2019
CUDA not available
Re: Command Line for Workflows
Thank you for the hint. It's another convenient way of creating interfaces between an application and Picture Window.
One suggestion I would add is that if you modify the MoveToDateFolder.wfl workflow, you should rename he file. The reason is that PWP installs this workflow. This means that your change will otherwise be overwritten the next time you install an update.
