remap black to red?
Posted: July 28th, 2014, 1:30 pm
by bbodine9
I am having trouble getting a black and white tiff file (converted from PDF) that is a construction drawing showing piling locations to change colors. I need to change the black circles representing the piling to red so that I can overlay it with the proposed new piling and print it on a large format color plotter to look for overlaps etc. Both remap and color correction do not seem to be working for me. Can someone offer a suggestion? Thanks in advance!
Re: remap black to red?
Posted: July 28th, 2014, 1:39 pm
by MarkT
If it truly a Black & White image (8- or 16-bit) it will need to be converted to either 24- or 48-bit Colour. (Convert Transformation).
Posted: July 28th, 2014, 1:59 pm
by bbodine9
I tried that and it did not seem to help but thanks anyway.
Posted: July 28th, 2014, 3:33 pm
by Dieter Mayr
Did you try Tint ?
Set it for a gradient from red to white instead of the default black to white.
If you want keep some parts black you would need to mask them out (you will have to do that with any solution, i guess)
Posted: July 28th, 2014, 4:10 pm
by bbodine9
Thank you Dieter, that solved the problem!
Posted: July 29th, 2014, 8:53 am
by couman
Color correction also will work (with mask), but you then need to increase the brightness to the desired level.
Posted: August 7th, 2014, 3:07 am
Adjusting Chroma/Brightness radii (and perhaps Tightness as well) in Remap transformation should do the trick (without masking).
