Update Available - Version 8.0.503
madhg
Re: Update Available - Version 8.0.503
Post by madhg »
The link to 8.0.486 doesn't work.
Sorry, should be fixed now.
madhg
Post by madhg »
Thanks, that's OK. I'll try this version out in a day or two
madhg
Post by madhg »
I've tried v.486, no problems.
We're getting close... I suspect this will work and the next one will not.
Here is a copy of 8.0.498 from April 30.
https://www.dl-c.com/Documents/Picture% ... %20498.msi
madhg
Post by madhg »
Yes, 498 works.
Here is a copy of 8.0.500 from May 4. This is the one that I predict will not work.
https://www.dl-c.com/Documents/Picture% ... %20500.msi
When PWP crashes, are you doing anything with the mouse or is there any other background activity or does it crash all by itself? If you are doing something with the mouse, what?
madhg
Post by madhg »
500 works properly, but 504 behaves like 503. If I've opened one image, and then try to open another, the yellow banner appears briefly, and half a second after it vanishes, PWP crashes. I use the mouse to select the photo to be loaded, but don't touch it after that.
When I open PWP again, it says the last session terminates abnormally, do I want to ...
I hope this helps, but I'm happy to use 500.
Does this happen with all file types or just raw files? Are you using the Raw Develop transformation?
Well so much for my theory about where the problem was -- I have one last version for you to try:
https://www.dl-c.com/Documents/Picture% ... %20502.msi
