Calendar bug ?
Bernard
Calendar bug ?
Post by Bernard »
I am using PWPro 7.0.14 and a french version of windows 7.
I used the calendar transformation for the first time, and was pleased to discover that the calendar was in French.
However the first month heading is not displayed, and the 'January' (ie Janvier) heading is displayed on the second month ( I specified : start on Jan 2015) , so the last month heading is november.
It looks just like a heading shift, the dates looks ok.
Bernard
ksinkel
Re: Calendar bug ?
Post by ksinkel »
Unfortunately the bug you describe was recently introduced into the Calendar transformation. The bug will be fixed in the next update.
However since this is the time of year for making calendars, I have re-posted PWP 7.0 11 which works correctly. It can be downloaded here: http://www.dl-c.com/Temp/downloads/Pict ... efault.htm
The link is to the 32 bit version. If you are currently running the 64 bit version, you can simply install the 32 bit version and it will run alongside your current 64 bit version.
However if you are running a more recent 32 bit version, you will need to remove it before you can install PWP 7.0 11.
Re: Calendar bug ?
Post by Dieter Mayr »
Thanks, Kiril!
I was just to report the same as i'm finishing my calendar now, too.
Just to complete, this occurs in single month layout, too. (Suppose it does in every layout).
Bernard
Re: Calendar bug ?
Post by Bernard »
Thanks Kiril !
I will install that 32 bits version alongside my 64b.
Bernard
Bernard
Re: Calendar bug ?
Post by Bernard »
Everything went ok with the calendar and PWPro 32 bits.
But after uninstalling PWPro 32 bits, my PWPro 64 bits does not execute anymore. Just nothing happens.
Any suggestion ?
Bernard
ksinkel
Re: Calendar bug ?
Post by ksinkel »
You should reinstall PWP 64. The two versions of PWP share some components. Uninstalling PWP 32 has uninstalled them.
Bernard
Re: Calendar bug ?
Post by Bernard »
OK thanks, works fine now.
Bernard
