Update on using RAWTherapy.
I'm happy with what it is setting up in the way of TIFFs for PWP.
However on over exposed shots it is well worth a fiddle within RT as there is lots more in the highlights if you look.
How much do I need to do with the RAW transformation?
tonygamble
Re: How much do I need to do with the RAW transformation?
In DxO adjustments, you can set Exposure Compensation to give low, medium or high priority to highlights.tonygamble wrote: ↑March 6th, 2025, 12:17 pm Han.
I seem to get more space at the side of my curves using RT than DXO - so assume they are less likely to clip.
