Where can I find the default settings for Multipass Sharpening please.
I have read the .pdf but there is no screen shot for Pass Three. There are two for Pass One and they are different.
Tony
Re: Multipass Sharpening
Sorry, I have my own set of defaults that I regularly use, but they are different from the defaults built into the program.
Here is what I use as default settings:
The settings for Pass 3 do not matter since Pass 3 is disabled via the 3-button tool bar.
Depending on the image, I generally adjust the Pass 1 Blur Threshold to taste.
Once you enter these settings, if you use the Settings menu (via the Gear icon in the dialog box) to save them as the defaults, they will come up every time you start a new Multipass Sharpen.
tonygamble
Brilliant.
Many thanks.
Tony
Many thanks.
Tony
For the next release I updated the pdf and added a settings file to the install script.
I figured I'll mention it here - my sort-of technique to visualize what the Multipass Sharpening will do to the image.
I made these settings the default starting point for images that I want to sharpen from scratch.
At the initial settings, the output is unaffected.
I start from increasing blur radius to blur the whole image, remembering that what's blurred will be sharpened eventually.
Then I decrease the Blur Threshold to 'unblur' the coarse edges (thus excluding them from eventual sharpening).
At this point, I move Sharpen Threshold sliders. This 'unblurs' the finest details like grain or fine texture, again protecting it from eventual sharpening.
At last, I 'convert' blur into sharpening with the Sharpen Factor slider and limit the halos with Halo Limit slider.
One interesting observation is that the two blurring methods in Settings - bilateral filter and guided filter - offer different results and are quite interesting to experiment with.
A nitpicking question: for the Sharpen Threshold slider, wouldn't flipping the black and white direction be more intuitive, as in 'full effect = the white slider all the way to the right'?
On the other hand, maybe it's logical and intuitive the way it is if I imagine the Sharpen Threshold slider as representing the roughness scale (similar to the Advanced Sharpen roughness). The slider blocks the 'roughness' from sharpening starting from fine on the left to increasingly courser to the right.
I think it used to be the other way around and I changed it due to complaints.
tonygamble
Majeic, Good to see that I'll give it a try. Most interesting.
Snag for me is I am a batch man and don't have the time to do that level of adjusting on my first run. I can do it with the shots that 'sell' but with about 100 in a folder it is not practical.
Looking at the two defaults that Jonathan suggested which single slider would you use to get a quick fine tune as I rush through my 100. Not questioning J's recommendation but curious about your workflow.
Re: Multipass Sharpening - question about order
Does the order in which passes are executed make a difference?
For example : small to large radius or the other way around.
