performance : Auto White Balance slow ?
Using the Levels and Color transformation, PWP stopped responding for a while, with the Remove Color pop-up being displayed "not responding" in the status bar. After about 15 seconds, the app was fluid again.
Workflow script attached.
2024-11-26 PWP Remove Color not responding.jpg (87.35 KiB) Viewed 4097 times
20241027_155210_conv v1.jpg.script
(3.28 KiB) Downloaded 204 times
Re: performance : Auto White Balance slow ?
I have seen similar things happen here more or less at random -- I believe this may be a problem with the Windows task scheduler or memory manager but I don't have any real evidence one way or the other. There were similar problems early on with the Windows scheduler causing long delays when running on computers that had a lot of cores. There is nothing that I know of in the program code that could account for these random delays.
I would keep an eye on "Levels and Color - color balance", since I have seen it happen many times on this specific transformation, as witnessed with the color picker popup showing "not responding".
Re: performance : Auto White Balance slow ? - crashed
Levels and color balance ceased responding then crashed PWP. See attached debug info.
PWP state and crash recovery.zip
(2.97 KiB) Downloaded 199 times
I have tried a number of times and cannot reproduce this issue, nor has anyone else reported it.
Have you tried using the color picker pipette for the "remove color" patch ?
Yes
