An update is available to Version 8.0.377 (1-Aug-2023)
Crop Transformation: fixed problems with dragging the sides of rotated cropping rectangles and with dragging the output image to move the center of the cropping rectangle. Added a list of common proportions to the popup menu displayed when right-clicking on the input image.
Added File submenu to right-click popup menu on thumbnails in Image Browser.
Speck Removal Tool: fixed problem of not reporting a size mismatch if input image has different pixel dimensions than the last time.
Fixed problem of main window not being redrawn correctly in some cases after canceling a top-level transformation.
Update Available - Version 8.0.377
Re: Update Available - Version 8.0.377
Thank you very much !
Two comments for the crop transformation :
1 Landscape/portrait could be brought up in the crop box right-click menu.
2. Proportions : A in the right-click menu, corresponding to 4 in the dialog box dropdown, appears to be a bug.
1) Landscape/Portrait is already at the bottom of the menu
2) Fixed for next release.
1) what I meant is brought at the very top ( before specific proportions )
