Problem with 2:1 Transformation Preview Panes when Using Mask
To reproduce:
1. Open PWP
2. Create the Resolution Chart Test Pattern
3. Open Transformation which uses the Preview Pane (Adv Sharpen, PGB, MP Sharpen, etc.)
4. Ensure that the Preview Pane does not display the entire Resolution Chart Test Pattern
5. Select New Mask from the Amount slider in the Transformation
6. Select the Title Bar of the Transformation window to return focus from Mask window to the Transformation window
7. Click on a portion of the Resolution Chart Test Pattern in the Main Image Area that is not currently displayed in the Preview Pane
8. Expand the Preview Pane to display the entire Test Pattern
9. Change the Preview Pane to 2:1 magnification
10. Note that an incorrect preview image is overlaid on the left portion of the Preview Pane
jfoster
Re: Problem with 2:1 Transformation Preview Panes when Using Mask
I tried these steps on my laptop and noticed that an additional step is needed to reliably reproduce the problem.
Insert step 6.5 (in between steps 6 and 7 above):
6.5 Select the Display Input toggle for the Preview Pane
