PWP is unresponsive on starting. It's the old problem doc.
I posted about PWP being unresponsive on starting a few weeks ago ("PWP is unresponsive on starting. "). This has happened again. I was running 8.0.171, so I removed it and installed ..173 and still frozen on start (with buttons not greyed out). As before though choosing 'open with' from the Rt click menu of a number of tiffs or jpgs opens the program. HPZ230 Xeon with Nvidia quadro p620 graphics card if this might be the culprit. Thanks for PWP I love the way it works.
Re: PWP is unresponsive on starting. It's the old problem doc.
Further info.
Having opened the program from a tiff's or jpg's rt click menu it is now opening as it should from the program's shortcuts and not freezing.
I rebuilt the debug version of PWP for the latest release. First you need to download the zip file:
https://www.dl-c.com/Documents/Picture% ... 0Debug.zip
Next, locate the folder PWP is installed in -- normally C:\Program Files\Digital Light & Color\Picture Window Pro 8
In that folder, rename PWP 8.0.exe to something like PWP 8.0 Release.exe
Next double click on the zip file you downloaded and drag PWP 8.0.exe to the PWP install folder, effectively replacing the release version with the debug version.
Now launch PWP normally -- it will display a series of messages as it goes through its startup -- let me know the last message it displays. That will let me know where in the initialization sequence it is failing so I can localize the problem.
Finally, you can delete the debug version of PWP 8.0.exe and rename the release version back to PWP 8.0.exe.
Since it seems to work if you pass a file to it, processing the file is the last thing in the startup code, so everything before that is probably working.
If there is no file to open on startup, PWP looks at the setting in File/Preferences called On Startup. Depending on how that is set, it may be trying to ask you for the name of a workspace to load. Please check that setting and let me know what you have it set to (Don't ask to load workspace/Ask to load workspace).
Thank you. It is set to ask to load workspace.
Finally, the debug version of PWP started and ran OK.
Try setting it to don't ask.
When PWP was unresponsive, did it ask to load a workspace before becoming unresponsive? If so, what response did you make?
Is it possible that the dialog box asking to load a workspace somehow got covered up by the main window? Since it is a modal dialog box, this would make the program look unresponsive since it was waiting for you to respond to the dialog box.
Set to 'don't ask' it again opened OK.
It did not get to ask to load a workspace when it was frozen.
If it happens again I will carefully check for a hidden dialog box.
I forgot it's not midnight where you are - I assume any way that you are not in the East of England.
Thanks again.
Thanks again.
No problem, I'm a morning person in the eastern time zone of USA
