Hi,
PWPro 5.0.1.2
Windows XP
When in the RAW Dialog, if I reset (either ctrl-R or the Options down arrow...Reset to RAW Settings), the Color Temp slider (and listed value) and the Tint slider (and listed value) do not change.  The image itself does change, but these two sliders remain at the old (wrong) values.
For example, if set to Camera White balance (5696K and tint 1.11 in my example) and I choose Daylight, the white balance and tint change to 4800K and 1.13 respectively...the white balance of the image itself does change to daylight white balance.  ctrl-R causes the image itself to change back to 5696K and tint 1.11, but the sliders stay at 4800K and 1.13.  The drop down for white balance selection does update to the proper value.
Can anyone else confirm this behavior?
Darren.
						RAW Dialog - Reset does not reset all sliders
				MikeG
Re: RAW Dialog - Reset does not reset all sliders
Darren,
PWP 5.0.1.2; Vista 32
I tested by going to and from Camera default and RAW Setings several times. Sliders changed OK for me.
PWPro 5.0.1.2 Vista 32
I confirm Darren's finding. The RAW dialog behaves exactly as Darren described it - "Reset camera to RAW settings" does not reset the values on Color Temp and Tint sliders ("Reset to Camera default" works correctly, though).
Cheers,
Bogumil
Cheers,
Bogumil
Bogumil
				MikeG
Very mysterious.
Reset to RAW settings, or Ctrl-R, move the sliders for me.
Thanks for the reports. This is now fixed and will be available in the next update.
Thank you for testing/confirming and fixing :)
Strange though, that Mike's works fine.
Darren.
Darren.
