Build Scanner/ camere profile... crashing
Moderators: ksinkel, jsachs
I mistakenly clicked on the Build Scanner/ camera profile... command it the File menu, which resulted in PWP 7.0.8. 32-bit crash. There was no camera nor scanner conected to the PC.
I repeated it a few more times to rule out any momentary faintness of my drowsy notebook but it always ended up the same.
David
Re: Build Scanner/ camere profile... crashing
This command is unrelated to any connected scanner or camera.
What are your color management settings? Do you remember what kind of window was selected when it crashed?
The CM was set to Disabled.
It seems to have something to do with the undocked Browse window:
1. it only happens when the Browse window is open (and) undocked before trying to open Build Scanner and Profile window.
2. once the Build Scanner and Profile window gets open succesfully (no undocked BW) and then closed, there is no crash later on under the circumstances described in 1, but only as long as the session lasts.
test steps:
1.
start PWP with undocked BW
or
start PWP, open BW and undock it
then
PWP crashes
2
start PWP with docked BW
or
start PWP with no BW
or
start PWP like in 1 and close or dock BW
then
PWP does not crash
David
One more comment to add to 2.
The problem seems to happen only if the undocked Browse window is active. If there is another window active like an image, PWP does not crash.
David
David,
This will be fixed in the next release. As a work around in the meantime, make sure that the target image is displayed and selected when you click Build Scanner/Camera Profile in the menu.
Kiril,
this is not a problem. As I mentioned at the beginning of the post, I clicked on the Build Scanner / Camera Profile unintentionaly - instead on the CM. After that I just wanted to find out more to report it with some additional detailes.
David
