PWP 7.0.7-32 -- Defringe - stops working
Moderators: ksinkel, jsachs
I have experienced three intermittent instances where after extended usage of the Defringe transform with Auto Preview checked and a 3456x2304, 48-bit color image that the transform stops working... ...the Preview does not update regardless of setting changes made or shift-left clicking on the Amount Mask button to blink Preview. There are no error/warning dialogs.
Memory and CPU usage remains low with no sudden surges or change.
Edit 1: Number of threads = 4; 2053 MB swap file space.
Closing the transform and re-opening will restore it... ...or closing the session and re-opening the program will also restore it.
Additionally... ...Off Topic suggestions for this transform:
(1) change the default Preview zoom to 1:1 to match the Chromatic Aberration transform
(2) add this to the Workflow available widgets... ...it would make a terrific companion to the ChromaticAberration widget when both are used sequentially [CA, then Defringe] and with 'breakpoints' in a Workflow.
3 GB DDR2 dual channel RAM
2 MB ReadyBoost Cache
Re: PWP 7.0.7-32 -- Defringe - stops working
Just a note on available widgets: There is a Defringe widget. It is under Color in the Widget menu of the Workflow window.
This should be fixed for the next release.
Charles2
Defringe volatility
Post by Charles2 »
I used the new Defringe transformation to remove purple fringing on shadowed twigs against sky. Very good result!
The effect was nil at amount 0.2% and full at the small amount 0.3%. Not a problem. However, if the behavior is not related to the bug reported above, I mention it in case you want to note add a line to the instructions.
I'm not sure I understand -- in examples I have here, the defringe effect phases in smoothly from nothing at 0% to full at 100%.
Were you using a mask? Can you post a small piece of the image and give the settings you were using?
Charles2
Post by Charles2 »
Yes, it happened with a mask made with a blur of roughly 30, not when I switched back to no mask. I thought the blur region did not go into the area affected by defringing, but that was judged by eye, so who knows.
Probably behavior too obscure to worry about.
